FLETAN
Re: FLETAN
Messagede J.J.85 » Dim Mar 03, 2019 12:00 pm
hi praia limpa how s going your rehabilitation ?
Re: FLETAN
Messagede Praia Limpa » Dim Mar 03, 2019 12:05 pm
Hello
Friend send me this photos sailing on motor and decide it to share
This is a test for a wood mast but I found one aluminium for a decent price so wood will have to wait :-(
Best regards
Praia Limpa
Re: FLETAN
Messagede Rase Cailloux » Dim Mar 03, 2019 12:23 pm
Très joli un assemblage en" bec de perroquet " :D
Mais c'est assez complexe de maintenir les différentes lattes pendant le collage.
Le mieux est de le faire avec des élastiques.
Ne pas oublier de disposer des inserts de renfort en pied et tête de mat et au niveau du capelage des haubans .
Re: FLETAN
Messagede old gaffeur » Dim Mar 03, 2019 1:28 pm
Translation of rase cailloux' message
A very nice 'parrot beak' assembly!
Tu it's quite hard to keep the different wood pieces together during gluing.
The best way is with rubber bands.
Doi not forget to include =inside strenghtheners at the base and top of the mast, as well as where the braces are to be attached.
Nice job, and nice boat, by the way!
Re: FLETAN
Messagede Rase Cailloux » Dim Mar 03, 2019 2:58 pm
Tu peux rajouter :
Pour un petit mat comme celui la, on utilise plus fréquemment la technique des deux planches évidées et collées à contre-fil.
c'est largement suffisant !
Mais en bec de perroquet c'est nettement plus professionnel :D
Re: FLETAN
Messagede old gaffeur » Dim Mar 03, 2019 3:08 pm
Translation of RC latest message ;)
For such a small mast, the usual technique is simply to use to wood planks, hollowed, and glued on opposite grain.
This is more than enough.
But the 'parrot beak' technique is much more professional!
Re: FLETAN
Messagede J.J.85 » Dim Mar 03, 2019 4:54 pm
Vverry nice piece of carpentry indeed as long as you ve got a decent idea of the process to use and a decent aluminium alloy mast handy for less trouble and much less money why would you go looking for bother
by tue look of tle pictures a bit of weight behind tue bow i d say 30 to 50 kilos would make her sail flat with anoutboard ,but do have her under sails to figure it aout properly
Glad to know everything s goung fine in lusitania at last
i dare say you ve done a verry good job indeed :D
Re: FLETAN
Messagede frémi » Lun Juin 03, 2019 11:02 am
Rase Cailloux a écrit:Tu peux rajouter :
avec toi ! j'ai fait comme ça pour un cotre il y a des années, ça m'a permis de passer les câbles élec.
frémi
Re: FLETAN
Messagede Praia Limpa » Ven Juil 19, 2019 7:27 pm
Olá
Sorry for late reply ive been working on mast boom etc
I get this blackandwhite photo from friend ...before 20 miles upthe River Tejo on sails.
Great experience :-)
Thanks to all the people who helped going up the river and going down.
I Used Navionics app for helping on root . Nice app.
Finally get a used mast for cheap and made the boom with aluminium tube.
More fixes to come and ill let you know about it
Best regards
Praia Limpa
Re: FLETAN
Messagede old gaffeur » Ven Juil 19, 2019 8:23 pm
Good to get some news! Seems you are enjoying your Flétan allright, which is the only important thing.
(Traduction:
Sympa d'avoir des nouvelles! Tu sembles t'amuser comme il faut avec ton Flétan, ce qui est la seule chose importante)
Retourner vers Flétan
