Page 1 sur 8
FLETAN
MessagePosté: Mar Oct 09, 2018 7:17 pm
de Praia Limpa
HELLO
I NEED HELP TO IDENTIFY THIS BOAT MODEL AND CONSTRUCTOR
THE RECORDS (REGISTER) HAVE FEW INFO ABOUT IT AND ONLY A PAPER SAYING IT CAME FROM FRANCE IN 1987
I THINK THIS IS A BENETEAU FLETAN CAN SOME ONE CONFIRM THAT PLEASE.
IM WONDERING IF THE SET UP I HAVE IS THE ORIGINAL WITH THE MASTE IN ALUMINIUM AND OTHER STUFS.
I JUST DOWNLOAD THE FILES AVAILABLE IN THE FORUM TOPIC FLETAN FICHE TECNIC
ALL TECNICAL INFORMATION AND HELP WILL BE GREAT FULL
BEST REGARDS
FLETAN 01.jpg (79.82 Kio) Vu 2292 fois
FLETAN 02.jpg (421.28 Kio) Vu 2292 fois
FLETAN 03.jpg (406.46 Kio) Vu 2292 fois
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 8:09 pm
de old gaffeur
Hello,
It actually looks like a Fletan. Some of these had wooden masts, others had metal ones.
Bonjour
Il ressemble en effet à un Flétan. Certains ont eu des mâts en bois, d'autre en métal
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 8:16 pm
de Terenez
Hello,
I'am quitte sure your boat is a Fletan. You can find the original files on the official Beneteau website http://www.beneteau.com/fr/fletan-0.
I think also you have the original mast and boom.
Juste a remark. On my mind, there is a problem with the boom, la retranca in portuguese language. There is an anormal
I think that some members can help you (Gwengolo, Phil29...).
Good luck
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 9:17 pm
de Praia Limpa
old gaffeur a écrit:Hello,
Bonjour
THANKS OLD GAFFEUR
MY MAST IS ALUMINIUM AND I´M NOT SHORE IF THIS WAS THE ORIGINAL ONE
THANKS
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 9:20 pm
de vincent
Yeah ! Sure it's a Fletan !
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 9:46 pm
de Praia Limpa
THANKS TERENEZ
I´VE ALREADY DOWNLOADED ALL FILES AVAILABLE FROM BENETEAU WEBSITE AND FROM THE FORUM BENETEAU4EVER THANKS TO ALL MEMBERS
THE BOOM IS DAMADGE AND I ALSO HAVE LOTS OF THINGS TO FIX
MAINSAIL IT´S HIGHER THEN THE MAST
THE MAST IS REPAIRED LIKE 2 PIECES TOGETHER
DONT KNOW IF THE MAINSAIL BELONGS TO THIS FLETAN OR ITS FROM OTHER BOAT
DONT KNOW IF THIS MAST IF THE ORIGINAL AND CORRECT MEASUER
DONT KNOW WHEN THIS BOAT WAS BUILD BECAUSE I ONLY HAVE 1987 REGISTER IN PORTUGAL, CAN YOU TELL ME AT LEAST TILL WHEN THIS MODEL WAS MADE ???
ABOUT THE RUDDER I ONLY HAVE THE MAIN RUDDER NOT THE SECOND PART OF IT.
THANKS FOR ALL
FLETAN 04.jpg (346.79 Kio) Vu 2276 fois
FLETAN 05.jpg (376.33 Kio) Vu 2276 fois
FLETAN 06.jpg (329.6 Kio) Vu 2276 fois
FLETAN 07.jpg (330.49 Kio) Vu 2276 fois
FLETAN 08.jpg (347.64 Kio) Vu 2276 fois
Re: FLETAN
MessagePosté: Mar Oct 09, 2018 10:16 pm
de old gaffeur
Your boat seems to be in good shape!
Your mast may have been broken and repaired. I'm no expert, but you'll need to check whether it's still strong enough. If the boom is also damaged, you may be better off changing both pieces altogether. This may be the best occasion to find one that fits your sails... ;)
Re: FLETAN
MessagePosté: Mer Oct 10, 2018 8:29 am
de phil29
At least you have a rudder... :D so much fletans have no one! Your boat seems really clean! ;)
Re: FLETAN
MessagePosté: Mer Oct 10, 2018 9:24 am
de Rase Cailloux
Traduire SVP car pas le temps, pas envie et de plus en langue étrangère je ne parle que la langue des signes, et pas facile sur un clavier .
Donc traduire :
Bonjour :D
bome tordue
pelle de safran trop petite pour faire de la voile.
Bas étai avant ne doit pas être amuré sur l'étrave
Merci ;)
Re: FLETAN
MessagePosté: Mer Oct 10, 2018 9:55 am
de Terenez
Rase Cailloux a écrit:Traduire SVP car pas le temps, pas envie et de plus en langue étrangère je ne parle que la langue des signes, et pas facile sur un clavier .
Donc traduire :
Bonjour :D
bome tordue
Merci ;)
Translation
Hello,
Your boom est anormaly curved
The rudder is too short to sail
The babystay don't be fixed on the stem but behind
